Hey guys, I know some over you are already on a rant on someone else's question pertaining to suspension. But I was gonna run my future set up by you guys before I finish buying it.
Items I have:
Hotchkiss drop springs all the way around
Bilstein shocks all the way around
Spohn Sway bars 1 5/16" in front 1" in back
UMI Boxed LCA in rear, and tubular UCA All with poly bushings.
12:1 quick ration steering box
All new MOOG tie rods, centerlink, pitman arm
Spohn tie rod adjuster
SC&C front frame braces
(I also have belltech 2" drop spindles, but I don't think I will use them)
What I need help with:
Front a-arms
I was thinking:
Spohn tubular upper and lower a-arms with poly bushings lower will have the spring box
OR maybe spome SPC upper control arms, only thing is I have no clue how to adjust them or anything like that.
I am using SSBC quick change dual piston calipers, stainless steel lines, and cross drilled and slotted rotors.
This car is a street car, may see SOME strip time like once or twice a year.
I really want something that can handle the turns and braking as good as it goes in a straight line. I have the brakes already, I was going to do Baer just no $ for it you know?
All suggestions and help would be much appreciated. Let me know if I made some poor choices on what I've bought. This is the first time doing this for me.
THANKS GUYS
Items I have:
Front a-arms
I was thinking:
THANKS GUYS
