So, I'm hopeful someone can bail me out with this one...
I just finished installing UMI upper and lower control arms, UMI sway bar and Viking coil-overs. Ride height was set and all was well.
After driving about 70 miles the passenger side dropped down almost an inch. The driver side did not drop but I didn't notice it until I thought about it after running into the next issue...
After I adjusted the driver side higher and put the car back on the ground the passenger side was sitting where I originally set it. Would preload and how tight the control arm bolts have anything to do with this?
The pic below is where the original ride height was set.
Any help is appreciated!
