I've done a lot of searching, and found a lot of varying opinions.
I just got my 79 Cutlass (260), and I want to upgrade the suspension first. I'm not interested in lowering the car, but if the best setup lowers it an inch or two, that's fine. Here is my simple plan:
Front - quick ratio steering box - I have a Saginaw 605 (a whole other question thread), 1 1/4" sway bar with poly end links, new coils, and freshen up control arm bushings/ball joints, shocks
Rear - class II hitch, coils, add 7/8" sway bar, and poly end links, shocks
This car is simply going to be a nice cruiser that handles better than it did, stock. I may put another engine in down, the road, but not considering that now.
Three main questions:
What coils and shocks would everyone recommend for this project? I don't mind paying for something that is clearly superior, and I'm doing the back first, then the front, so I'm saving up for the project over time.
Is there anyone that sells a 600 box with the quick-ratio steering? I'd rather re-use the SAE lines, hoses, mount, and pitman arm.
Thanks!
Tom
Thanks!
Tom
