Both poly bushings and boxed/tubular control arms cause binding and induce more stress into the control arm mounts that can twist or shear them. The rear suspensions on these cars were designed to have lots of flexing as part of normal operation to avoid binding and snap oversteer. The only aftermarket arms that do not have binding problems are arms with poly ball joints. http://scandc.com/new/node/646 Most aftermarket suspension parts for these cars are intended for drag strips where you mostly just go straight, most are not designed for high speed turns like normal street and highway driving. About the best upgrade is to replace the lame stock rear sway bar with a aftermarket axle mounted rear sway bar which reduces binding. http://scandc.com/new/node/684
