442 Swap automatic for 5 speed
There is nothing inexpensive about a manual swap. You need:
  • Flywheel
  • Flywheel bolts
  • Clutch disk
  • Pressure plate
  • Pressure plate bolts
  • Throw out bearing
  • Pilot bushing
  • Bellhousing
  • Clutch linkage or hydraulic setup
  • Transmission
  • Crossmember
  • Transmission mount
  • Shifter
  • Pedals
  • Drive shaft
And more miscellaneous stuff.
The T56 Magnum (great transmission) costs north of $3k. Figure nearly $5k to do the swap if you just buy everything and bolt it together. You can buy a regular T56 or a T5 (not as strong) for less but I don't see you completing the swap for under $3k. That would be with buying a used transmission.
Not trying to talk you out of it. I'm swapping a T5 into my car. I just want you to have some idea of what a financial commitment it is to swap to a 5 or 6 speed. If you found a donor car (fourth gen Camaro with a T56) and have the skills to fabricate and to overhaul a manual transmission yourself, perhaps you could do it for a bit less but it is not a cheap proposition.
Also, be honest with yourself regarding how you will treat the car (abuse). Torque capacity:
WC T5 - roughly 300 ft. lbs.
T56 - roughly 450 ft. lbs.
T56 Magnum - 700 ft. lbs.
I have a SBC that is rated 350 HP/400 ft. lbs. so it is more than my T5 is rated for but I don't plan to abuse it. My car is a cruiser.
I hope this helps.
--Jared
If I read your post before I did my conversion I would not have done it, it looks like too much work....😀
You wouldn't have done it if you had to pay someone to do it.
The OP seems to be looking for someone to pay to do it for him.
Reactions: pontiacgp
Someone who was impressed with the stick in my GP was bugging me to convert their Regal, I gave him a price of $5,000 plus he has to get the parts. If he said ok I would have been upset with myself cause I didn't want to do, I wanted him to stop pestering me
Reactions: CDUNIGAN1981
