Tank swap for fuel injection
Monte 4.3L TBI gas tank and sending unit then swap on whatever Walbro pump you want
One thing I’m confused about is the sending unit. Can you have too much hp for a sending unit or only the fuel pumps? Also I don’t think a single walbro pump will be enough with it? Some people I’ve seen running dual pumps
Yes you can. A 3/8 line can only flow so many gallons.... It should be enough to support 600hp though. You planning on more than that? Obviously you'd need a good, maybe 300lph pump to support 600hp. Maybe even a 450lph
Reactions: Injectedcutty
Yep!!! I looked at the 340lph pumps, and they seem to die off around 550whp on an NA setup. Add in boost and it's definitely not enough pump! I will be running a 450lph pump which is good to 800ish. I'd rather over-pump an engine and tune it properly, than under-pump one and have to set it on kill which will wear it out WAY faster!
Please re-read the 1st paragraph of my last post, and I'll explain further. The pump requirement for E85 will be somewhere between 30-50% more volume to make the same HP as with gas. This due to the energy content, or lack of, for E85. Hence, the requirement for much more volume (pump). The biggest Walbro intank pump you can buy will be coming up short of 600 crank HP (500ish wheel HP) with E85. Hence the reason for two pumps or a large pulsewidthed pump.
If you try to run two pumps in the stock tank you're going to find that you'll be hacking the crap out of the tank to get both in and functioning along with the sending unit. Also, the 3/8 line size will get you to your 500whp goal with gas (barely), but will be undersized for E85 at that HP level. At 800 wheel HP on E85 you'll need 5/8" (#10) line. Installing that size line in to the stock sending unit will be almost impossible without cutting a hole in the truck for access.
I seen you mentioned you're looking to use the factory harness and ECM. There isn't a provision to run two pumps individually with that. But you can have one of the pumps run via Hobbs switch or aftermarket switch that will turn it on at 'x' amount of boost.
I do understand the concern for using stock parts, especially for appearance, but you could really use a sump with external pumps. Or a cut, weld, refrabicatation of the stock tank and sending unit. 800wheel is going to be 900+ crank - that's ALOT of go. I'm sure you can get this fuel system done on your budget of $1000-1200, but I'd recommend going at it differently.
Good luck - Jim
What are your goals with this? 800 wheel sounds cool but is pretty much useless on the street. Do you have enough turbo/supporting modifications to support the power level? Two 450lph pumps will probably be ok at that level on e but you're getting close to the edge.
Are the Monte and grand national tank exactly the same? Is one better than the other? I’ve read where some people have had filler neck issues with the tank not being centered on the grand national tank . Are the inside designs the same?
The tanks are the same as far as I know but the necks are different brand to brand hence why I used my neck from my original tank
I used an aftermarket GN tank in my Malibu. It works fine aside from being hard to fill quickly due to the lack of proper venting would be my guess. Just makes it so I stand behind the car looking like a perv for longer.
I’m running a 6.0L 7875 billet turbo. 4l80e and I’ll most likely be swapping out the 8.5 for a 9”. My plans are around 500whp at first with the 8.5 then once I get the 9” on there I’ll turn the boost up and e85 it. I don’t want to buy parts twice so I would like to build my fuel system up to be able to support 750-800hp on e85
Reactions: Turbolq4
A walbro 450? Is that enough pump to flow e85 at 800hp?
