Hi guys,
I wanted to get a little info or thoughts about my Cutlass engine. I bought the car with this already in it. I also do not know anything about engines in general so I'm hoping to get some info from you.
I've done a little research to try and look up specs and stuff based on the list I was given with the car.
I was basically looking for a decent Cutlass that I can drive, that hopefully doesn't need much work done to it.
Here's the list of engine specs:
The above is exactly what is listed on my sheet that I was given to me when I bought the car.
My first question is, do you think this would really have anywhere near 400 hp/500 torq?
This car doesn't feel that fast to me. I raced a buddy that has a 97 SLP SS Camaro and got walked. I also raced my buddy that has an 96 GTO exhaust only and got walked even more, wasn't even close.
Looking over all kinds of G Body 455 Olds builds around the net, it looks like my car should be running at least a 13 second quarter mile if the engine does have 400 hp.
I was thinking that maybe the engine was built for NOS or something like that. I showed my buddy that is a mechanic and has a NOS Corvette and he checked out the cam specs. He said that it would be blowing most of the NOS out the exhaust with the cam that I have, so it's most likely not a NOS engine.
This engine runs great, has a nice little lopey idle to it with the cam. Doesn't leak any oil, all I have is a small antifreeze leak that I need to track down. My only complaint is that if I'm going be getting big block gas mileage, I would like some big block power, if you know what I mean.
So what can you tell me about this build? Does this combo make sense?
From research I've done, I read that 425 "B" heads flow much like 455 "c" heads. I understand that C heads are the heads most people want for their BBO? Also, the list above is exactly what's written. I couldn't find anything about pistons with a part number 2214L. But doing some research, I think they might be part number L2214F30??? The F means forged, the 30 means it's for a 30 over engine? Is this correct, or not?
That's one reason I thought the engine might be set up for NOS or something.....since it has a forged crank, forged rods, and forged pistons. But I don't know anything about racing or engines, so what do you think?
I also don't understand why he would like "66 425 rods resized" along with "455 rods resized (2) 70 / (6) 75"
I also found out that a 425 engine is considered a square or something? Bore = stroke I think it was? This is not the case for a normal 455? Can someone explain this to me in a way I can understand. Also, can someone explain to me what the deal is with my setup? In other words, what kind of compression do you think it would have? What kind of HP do you think I would realistically get from this setup?
I wouldn't mind getting a dyno run so I can tell exactly what it's putting out, but they're so damn expensive. I figured I could run a couple buddies cars and go off of their specs to get a better idea
I'm running a ~3.56 rear end with a TH400 trans, stock stall I believe. I have no clue how to tell what kind of stall is in it, and there's nothing listed on the sheet I got. I believe it's an 850 Rochester carb with a 1 inch riser thing on it. Intake appears to be stock (I don't know if it's an intake off a 425 or 455, or if they're even the same)
Also, can you please tell me what the red line should be for engine, and what oil do you use for your BBO? Synthetic?
Please help a newbie out, thank you
Eng. 75 455 blk Fb 030 over (4.154")
66 425 forged crank
66 425 forged robs resized
trw-425 pistons, PN 2214L 10.25:1
66 "B" heads shallow pocket
Engle valve springs PN 361
Engle cam - PM 107* jm20-22H
.842 hyd lifters
11/1/94 - purchased 66 Olds toro w/ 425
400 hp.
500 torq.
