TH350 Cooling lines
79wagonator
182
17
Long Island, NY
Hey, Long time no post..
My trans cooling hard lines are rusted a bit & leaking. I want to change em to black braided lines & mount them to frame to clear headers & for bbc swap. Has anyone done this recently? Does anyone know what size fittings I would need for the trans side & radiator side? It’s a 79 Malibu wagon with original sbc & TH350.
Does anyone make a kit maybe?
TIA
Dave..
mikester
2,785
3,356
Small town NY
Important to know, the fittings on the transmission are not NPT. Those are straight thread. Using NPT can possibly crack the transmission case. I bought a set of stainless prebent lines from Inline and they fit fine.Might be easier than using braided. Theres plenty of room between the lines and header tubes.
565bbchevy
9,362
12,017
Michigan
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
11,882
9,225
Gainesville, Fl
TIA
Dave..
Hi Dave,
Good to see you back again. I think the last time(s) I spoke to you, you were contemplating swapping a big block into the wagon. I guess it was put on the backburner for awhile. Also, I think you were going to give the car to your son if I recall correctly.
All in all, it's good to see that you're back on the wagon again....you know what I mean. :LOL:
565bbchevy has a good point there regarding upgrading to a different transmission. Perhaps a TH400 or 700R4 depending on if you want overdrive or not.
melloelky
3,935
9,009
mass
the fittings you want are NPS,these threads are straight.the seal relies on a crush washer or o-ring.unlike npt that seals via a tapered thread.you're looking for something along the lines of 1/4nps-6 an to switch to a braided hose equal to the o.e steel line.
79wagonator
182
17
Long Island, NY
Hi Dave,
Hey Jack
Good to see ya still here kicking around. 😁 yeah I tried to give it to him so he’d have more interest but he’s busy getting his act together finding a career path (union electrician or job w MTA)
He was using it as a DD for awhile when my 95 Surburban I gave him to drive needed work & now the Th350 needs rebuilding. It only does 1st & 3rd and ya gotta shift manually 😳
79wagonator
182
17
Long Island, NY
You might want to look at a trans upgrade with a BBC install.
It’s gonna be a mild 461 street engine I’m gonna have him beef up the th350 when it gets redone. I think it should hold up fine.
That’s good to know! Thank you 😊 I bought the SS brake lines & fuel lines from inline. I wasn’t sure about the clearance with a bbc & headers. You think it’ll clear with slightly larger block & the starter n stuff?
79wagonator
182
17
Long Island, NY
Thank you👍 That’s the info I was looking for. I think there are adapters already on there already on the factory lines I guess NPS to a flare fitting?
mikester
2,785
3,356
Small town NY
I should have read slower. Didnt notice that it was a BBC. I used them with a SB.
565bbchevy
9,362
12,017
Michigan
On my BBC I have 8 AN braided lines but I mounted them to my wheel well to keep them away from my headers
