TH350 Governor Removal While Transmission In The Car
Tynan918
1,136
249
I want to take out my governor for inspection.
2nd and 3rd gear seem to shift fine, but 1st gear to 2nd gear is kind of rough, hesitant, and "jumps" into 2nd gear.
This car sat for a year or so I was told, and I'm reading that sitting will cause a governor to stick.
I've replaced the transmission filter and replaced the vacuum canister because transmission fluid was in the hose, indicating it was failing. I've adjusted the shift points by turning the adjuster screw clockwise and counter clockwise before, and it was hard to see a difference in shifting.
I see a lot of other guys saying the crossmember needs to be removed and the transmission dropped in order to get the governor out and replaced. Seen a guy on YouTube only remove his exhaust pipe and without dropping the transmission on a'79 Corvette in 30 minutes.
My thing is, the less I need to remove, the better and easier it makes things for me.
My question is, is there any way I can remove the transmission governor from a TH350 without removing anything else to get it out and in ?
08Malibu
1,455
3,420
North Jersey
How many miles have you put on this car since it was doing this? Did you check fluid level? Was your fluid in poor condition? Did you change the fluid and filter after the car was sitting a long time?
Also, your car could have a shift kit in it. My car has one and 1 to 2 shift will bark the tires if I’m on it, and I have a stock 305.
2ABodies1FBody
26
20
Maybe it can be done in a corvette, but I recently did on in my 79 Monte, and I had to remove the Crossmember and let the trans down some to get the governor cap out.
2ABodies1FBody
26
20
In mine, the plastic gear was stripped out from a low fluid condition, thanks previous owner...
Tynan918
1,136
249
Less than 300 miles that I have put on it since July 2021...
Tynan918
1,136
249
Maybe my setup is different...I have plenty of room to remove the cap and pull the governor out without removing the cross member or dropping the transmission...
Tynan918
1,136
249
Can anybody tell me why the top of the transmission would leak fluid from the top of the transmission ?
Was filling it up and heard a faint pop and gurgle sound to find some fluid leaking from the top of the transmission...
