I have a Pontiac 455 which had a TH400 on it from the beginning of time, great transmission but only has 3 low gears, but then I swapped the rear from a 7.5 with 2.41 to a GN 8.5 rear with 3.42's. Then I couldn't go on the highway with it because it was taching out too much for my engine so I got a GN TH200-4R and what a difference! I can cruise to the beach on the highway now going 80mph and around 2400 rpm. I also have the D5 lockup converter which I wired up and makes the crankshaft a 1:1 ratio with the transmission when going over 45mph. I only had 2.41's in the TH400 but it was still screaming on the highway, so your 3.73's will really make it tach out you won't like it. So far the GN TH200-4R is holding up well under the torque of my 455 and I really like the overdrive!
