Haven’t posted any updates in a hot minute, but progress has been moving forward. Albeit a little slowly. Since I last updated, a lot has happened so sit down, strap in and hang on for the ride.
I received the emergency brake handle and kit about a month ago, and it’s everything I imagined it would be. No pictures of it yet as I’ve only taken it out of the box to inspect and assemble some of its’ components, but I’ll post some up when I get to the install of it. But so far, and overall I’m happy with the purchase and feel it’s going to work well.
While I was waiting for that to be delivered, I started moving on to the next phase of the floor project, and it’s the biggest and most complicated. To refresh everyone’s memory, several years ago I had started to fabricate and install exhaust housing tubes for the side exit exhaust to go through:
During the hiatus from The Juggernaut working on Olds Cool, I had thoroughly decided that I wasn’t real happy with this and it didn’t fit the vision or direction I wanted to go with it. So it was time to go back to the drawing board and start fresh. That began with pulling out the exhaust system, dusting it off, and assembling it on the floor in preparation to get reinstalled.
Haven’t seen this assembled and in the light of day for a while!
I began the transformation by cutting out all the work on the passenger side that had already been done. Cut off/out the goofy exhaust pass-through tube, and exposed part of the rear floor crossmember:
Next was to remove the very end of the crossmember and the body mount underneath it.
From there, I finally had good access to cut out and weld in an “inner wall” and weld the now much shorter exhaust pass-through to it:
This is going to be the full length of the pass-throughs now, from the outer quarter panel to this new “wall” I just created. So how in the hell is this going to work now you ask? Stay tuned to find out.
The whole new rear floor has to be based around the crossmember, so that became the next area of focus. I whipped up what was to become the first of several new crossmember pieces on my metal brake…
…then proceeded to bolt the exhaust system back up. I still had these cut down pieces of masking tape rolls that I had specifically made to keep the pipes centered in the openings while fabricating, so they got pressed back into service once again:
With the tail pipe section in place, I could start determining if I had the necessary clearance to create a new body mount pedestal. I did this with a scrap piece of stainless tubing I had left over, and you can see that I do:
Next I had to take my newly fabricated crossmember piece and start mocking it up to figure out what had to happen. But first, I made an end for it and welded that on.
Next was to determine the centerline of the original crossmember and transcribe it onto the wall. The height at which it had to be was pretty easy to figure out, it was just simply as low as possible. The sharp-eyed among you out there that knows these cars will also notice that my new crossmember piece is quite a bit less tall than the original. That’s simply to keep the kick up portion of the new floor as low as possible since it sits directly over top of the tail pipe.
Once I had the centerline figured out, I temporarily attached the new crossmember to the inner wall with some Cleco’s.
Now obviously I don’t want the entire rear floor section to be this height, that would look ridiculous and be really hard to incorporate into the existing floor. So it was time to start figuring out what the shape the new crossmember (and ultimately the floor) would be.
Laid out some cut lines for reliefs…
Then started conforming it into a bend.
The downward bends were easy to create, the gaps expand as it’s bent. Just get the bend radius you want, then tack weld the gaps to keep the shape.
The upward bends however were quite a bit more tricky to do. The opposite has to be done, create gaps in the sides for the metal to close in on itself:
Using this method, I next proceeded to create several more pieces to make up the rest of the new crossmember.
Out of room for anymore pictures in this post, continued >>>
