Oh, forgot to mention, you lose the use of the factory seat belt boxes this way too. Not a big deal for me because I’m using Corbeau harnesses anyways.
Everything is a compromise.
Nicely done, looks great.Lots of test fitting, mock-ups and measuring, but it was starting to take shape…
Once I had the basic shape and heights established that I wanted everything at, it was time to get all the gaps closed up and welded together. This was an EXTREMELY laborious and time consuming task, it took me nearly 3 weeks to complete. At first I couldn’t figure out why, but after doing the math on it, it all made sense.
Every bend has to be welded back together in 2 sections: The side first to preserve the shape, then the flange. So with 4 crossmember pieces each having 2 bends in them each, that was 8 bends. Each bend has 2 sides, so now we’re up to 16 sections, plus the flanges, so times another 2.
That’s THIRTY TWO sections to weld in, not including the joints between each of the pieces!
Here’s how the process for each section went:
First, the gaps in the inside bends had to be welded up…
…then the inside corner cleaned up with the cutoff wheel:
Once the corner was done, then the face could be dressed:
Next was to cut out the “fingers” on the flange and make a curved piece to fit.
Then, burn it in, dress it out, and move onto the next.
THIRTY TWO TIMES!!! It literally took forever.
Anyways, I digress. After a while, I was finally getting the sections completed and ready to go:
Once I finally had all the sections done, it was time to start trimming them down to size and joining them together. I made a couple of little bridge insert pieces to add strength to the joints…
….then clamped them into place and burned them in with some rosette welds.
I used a long piece of heavy duty 1x1 square tubing as my fixture to make sure everything joined together flat, straight and true.
Damn if it wasn’t actually starting to look like something now!
I got 3 of the 4 sections welded together and metal finished out, but I purposely left the 4th section long and unattached. Just in case the lengths were unequal side to side. It wouldn’t take much of a discrepancy to have it not fit properly.
So that meant the next step was to create and weld in the inner wall on the driver’s side. That had to start by digging out the driver’s side pass-through and getting it Cleco’d in place too:
I spent an entire evening just cleaning up the pass-through and making the inner wall section for the driver’s side. Then the tubing had to be marked and cut down to match the wall.
And that’s pretty much where I’m at now. I don’t have any pictures of it yet, but the driver’s side inner wall has been fully welded in and ground flush, and the crossmember has been started on finalizing and getting positioned. It may not be terribly exciting for you, but it’s a mini milestone for me and I’m REALLY looking forward to the next steps.
Sorry for the long posts and all the pictures, but I was waaay behind on getting y’all up to date on this.
D.
Wait, whut? You mean it's not going to be stock? 😵Oh, forgot to mention, you lose the use of the factory seat belt boxes this way too. Not a big deal for me because I’m using Corbeau harnesses anyways.
You know it's going to be so much easier when you repaint my car when I drag it up there with the trunk full of toonies $$$. The hardest part would be putting on the rock guard. 🙂
I guarantee you that your car will end up in an e-magazine article somewhere when you're done. Totally impressive artistic solutions to obstacles with not much more than a welder and a grinder.
If it wasn't named the Juggernaut already, you could consider it the "Slick Brick". It's going to be form + function.
Wow, unbelievable work and a testament to your skill. It’s really an art form. it will be a shame to cover it up. Nice job!
Amazing work as always D. Your skills continue to impress! Keep up the great work .
What's the finished product that you envision for the back seat area?
