BUILD THREAD “The Juggernaut”
Very few will ever know or fully appreciate the amount of time and physical pain these pictures represent. Stages 6 and 7 are finally done.
To say this was a major undertaking would be an understatement. From the back window to the floor, from sail panel to sail panel, this piece spans a lot of real estate. It’s been almost a full week of 5-10 hours a day, stuffed in there on my knees, filling and sanding. My shoulders ache, my back hurts, and every time I went to stand up, I had to wait for the feeling to return to my legs. It was miserable to say the least.
But it’s done, and it’s done right. From the bead rolled feature on the package tray, to around the harness mounts and all the edges, it’s damn near perfect. I would have no qualms about painting this gloss black if needed, and we all know how good it has to be to do that. I’m that confident in it.
To say I’m relieved that this is done is another understatement. It’s ready for the black epoxy primer I picked up yesterday, but first I need to do some prep and finish work on the side panels. I’ll sand the backsides of them with the DA first so the epoxy has something to stick to, then I’ll lay out the new bead roll lines and get those done. The backsides will get sprayed first (because trying to spray them inside the trunk after they’ve been welded in would be a major PITA), then it’ll be onto welding them in.
SOOOO glad to be done this step and onto the next. Time for a well deserved break.
I feel your pain D mananas hours of tedious cramping. My hole body hurts looking at it. But the payoff will be when you see it in wet primer. I love that part.
And just like that, the “well deserved break” is over and we’re right back into fabrication.
Got the backsides of the side panels cleaned up and sanded in 80 grit on the DA, they were pretty scratched up but they cleaned up ok.
Then it was a ton of measuring and laying out lines on both sides. The measurements for the bead roll lines had to be done on the front side as the measurements were taken from the inside edges, but the lines needed to be transferred to the backsides in order to have the bead on the proper side of the panels.
I could’ve flipped the dies on the roller, but it’s much easier to follow the lines with the male die rather than the female die. You’ll note in this next picture that I didn’t like the initial placement of the top inside curve, it was too close to the edge in the corner. That’s why multiple test fits are always important.
After spending a couple hours trimming and refining the fitment of both panels, tonight after dinner I enlisted the help of the better half to run the feed on the bead roller and we got it done. I was extremely nervous about doing this, you only get one shot at it to get it right. Screw up even once and you’re done, throw it out and start over again from scratch and make all new panels.
Thankfully it didn’t come to that. Here they are Cleco’d in place, and I think they turned out great. Even better than the first set I did.
So now tomorrow night, I should be able to take them back out and shoot some epoxy on the backsides before punching a bunch of holes in them for welding them in permanently. Extremely relieved it went so well tonight!
D.
Looks awesome!
All this shows me is what I could accomplish if I didn't have kids... and had talent.
I absolutely love the direction this is going! D, your skill ceases to amaze us man, keep up the extraordinary work! This car is something special and the attention to detail you're giving it shows for sure.
Thank you very much Scott. Your kind words really mean a lot. I appreciate it very much.
It's really coming together. Getting an alien spacecraft kinda vibe. Incredible work 👏
Thanks Tony.
That spaceship vibe should be reduced substantially by the time some of the interior panels start going back in. Ya gotta look past things like the bead rolled reinforcing ribs in the floor because they won’t be seen under the carpet. Think bigger picture and try to visualize the end result, I think it’ll look obviously custom but not too over the top.
Wow, just wow Donovan 👌
Thanks Shawn!
When his layout lines look better than my finished product.....
Necessary evil for straight and matching mirror image beads unfortunately. The real challenge was accurately transferring them from the front side to the back.
Looks awesome!
Appreciate it, thank you!
Some people create life, others bring life to their creations. Not everybody is parent material. You undoubtedly made the better choice I’m sure.
Since I’m here responding to all your kind words anyways, I’m just going to post some of my recent thoughts and musings.
I had a bit of a revelation last night before bed, sometimes I forget this is the 21st century and that repair methods have improved and changed. Thinking ahead to making the side panels a permanent part of the rear firewall, I was originally going to just punch a bunch of holes in them and plug weld everything. But then I realized there’s a much better way.
I’ll still punch plug weld holes in things like the side tabs, but the flanges around the perimeters and the trunk brace that straddles the middles would be much better served by panel bonding them in place. Less distortion, no grinding, and no repairs with body filler if I should get a little carried away or go too deep with the grinder. Plus, the panel bond will act as a natural sealant to keep the trunk sealed off separate from the passenger cabin.
There will still be some holes that are going to need to be welded up, but those will be the Cleco holes. I’ll have to add a few more Cleco’s to evenly distribute the clamping force, but it’ll still be less intrusive than welding everything. Especially in the middles of the panels.
So that’s all, just a slight revision to my original plan.
I got the backsides of the panels shot with 2 coats of black epoxy tonight, right on schedule, so I should be able to start making preparations to get them bonded and welded in permanently tomorrow.
