I kind of lapsed in my documentation of the process, but here are the pictures of the finished framework on the face of the bumper.
It’s little difficult to describe, but basically the ends of the framework were made to fit by making relief cuts on the backside and bending the face to match the curvature of the bumper. Then the relief cuts were welded up again. Once that was done, I then knew the depth the top half of the framework had to be. It was cut down to match the lower half, thereby making a level mounting surface for the light.
Now we need to have a way of mounting the lights to the bumper. Just like I did with the bumper plates and studs, I drilled and tapped holes through the face of the bumper, cut some studs, and welded them in place.
One side figured out, now onto the other. I learned quite a bit on this first side, thankfully the driver’s side went quite a bit quicker and smoother.
Both marker light openings now completed, and the new set of non-mockup lights installed:
But we ain’t done with the fabrication yet, oh no, not by a long shot.
The top outer edges on both sides weren’t in the best of shape, they had been warped and distorted by me trying to hammer and dolly them into shape. If I had a Pullmax machine with custom made dies in the proper shape I could’ve fixed them, but since I don’t, the next best course of action was to cut them off entirely and replace them with two new good ones from one of the donor bumpers.
It’s a little difficult to tell here, but in these pictures I’ve overlaid the old warped pieces onto the replacements. They had definitely lost a lot of their shape:
Back on the car for another test fit, looks pretty good, but more tweaking was going to be in order.
I had purposely left the inner edges on both sides long so that when I mocked it up on the car, I would know exactly where to notch them to go around the bumper filler panel.
As you can see by my marks, I’ve allowed for a 1/4” gap around it:
I enjoy this picture, symmetry and flow is important when custom designing and building things. Note how all three things, the lights, the air intake, and the new marker light are all stacked creating a pleasing visual effect:
With things starting to progress pretty nicely at this point, it was now time to address something that had been plaguing me the entire time on this:
The bumper had slowly developed a nasty twist in it over time, presumably due to all the welding and related heat that goes with it. The end caps that are supposed to fit snugly into their pockets in each fender were not square and level in them.
I had to (un)do the twist so to speak.
Since leverage is your friend, and with a fulcrum and a long enough lever you can move the world, this was going to be the answer as to how to fix this.
It was redneck and backyard as all hell, but I clamped one end cap of the bumper to my workbench, and a long length of square tubing to the other while supporting the middle with my stand.
An inclinometer and a couple of digital angle gauges kept an eye on things, and let me know when I had provided the right amount of leverage to reverse the twist. It had developed a 5 degree twist into it, and by the time I was done correcting it, I had it down to 0.1 of a degree. Easily correctable with shim plates when the bumper is installed if necessary.
Continued >>>
Continued >>>
