Ok, let’s see if we can’t play a bit of catch up here. This will likely be long winded and with a TON of pictures, so please bear with.
This most recent saga restarted back in April, so that’s where we’ll pick up from. The first order of business was to get rid of all the rust on the backside of the bumper. A lot of it was surface, but a lot of it was also deep pitting. The 3M fibre wheel on the die grinder took care of most of the surface stuff, but removing the pitting required a much more aggressive action.
Every square inch of backside of the bumper got profiled with a 36 grit disc with special emphasis on the pitted areas. The disc was only 2” in diameter, so you can imagine how long that took to accomplish. I chose not to sandblast for various reasons, the least of which was fear of warping it more than it already was, and blow-through in some of the thinner spots.
This grinding step was extremely messy.
Note these two pieces of metal on the floor, these are corroded pieces of the aluminum reinforcement that were starting to delaminate along the edges:
They were no longer really required with this reinvention of the bumper, so off they came.
Once this labor intensive step was completed, the next task was to revisit the hidden fasteners that mount the bumper to the inner reinforcement. I had originally welded in studs in the original carriage bolt holes, but when the nuts were tightened up on the backside, they pulled and puckered the frontside.
Not good.
So after doing some research online to see how others had circumvented this problem, I decided to make six 1/4” rectangular plates that I drilled and tapped for 3/6”-16 1 1/4” long bolts. I cut the heads off the bolts, threaded them in to just below flush, then welded them in the plates. Once all six were made, I next welded the plates to the backside of the bumper inline with the holes in the aluminum reinforcement.
Now I don’t claim to be any sort of a professional welder, but I’m pretty damn sure they ain’t going anywhere. Also note the thin nylon washers on the studs. This is to prevent the accelerated corrosion that can happen from having two dissimilar metals like steel and aluminum in direct contact with one another. These plates and the nylon washers are why the bumper currently sits a half inch farther out than what it should.
Next I started messing around with cleaning up the aluminum reinforcement. It was pretty grubby, but mostly just had some light surface oxidation (other than the delaminated spots I cut off earlier), so I was relatively certain it would clean up well.
About halfway through, I decided that this was just simply too much work to do by hand, and for very little in return. Plus there were going to be several areas that would be nearly impossible to access without great difficulty. Nope, it was eventually going to get dropped off at the powder coaters for bead blasting and powder coat.
So, onto the next. I took the bumper stud to bumper shock plates into work one day, and gave them a thorough sand blasting.
It’s virtually impossible to get the serrated washers that hold the plates to the reinforcement off without destroying them, so I also grabbed some new ones when I stopped by the local auto parts store for some cans of VHT Satin Black spray bombs.
Fast forward a little bit, and I had gotten the reinforcement back from the powder coaters, and it looked great:
Plates painted and installed with the new retainers:
Although I had done a lot of work to this bumper already, I was still pretty green at the time and didn’t know what I didn’t know. Astoundingly, I had never established any center or datum line’s which would make getting reliable measurements nearly impossible. So that was priority one now before the rest of the fabrication could begin.
I started by laying out some strips of 2” bright orange masking tape on the backside to make the datum lines I needed to make clearly visible:
Continued >>>
