Have read pretty much all of this(I did skip a couple of pages though) and will say you do an amazing job, much better than I could ever dream of. I have an '86 El Camino as my first car that I got when I was 14, and will be 34 in January. It hasn't been on the road since 2008 I think though, but I have a 455 olds in it, although it spun a bearing, and it clears the stock hood with ease, and plenty of room around the ac box even though the ac is not hooked up. I did use the factory 1973 mounts from I think it was a 98, so maybe they are a little shorter than what most people use. Along with your mirrors, I know it may not exactly match everything and look as clean as you want, I would put them on for driving on the open road. I guess I have grown up on a farm driving trucks, and am used to using mirrors to back up, as I typically back into parking spaces with my extended cab long bed since its easier many times to see backing into a spot than backing out. My El Camino and the Monte's that have the sport mirrors like what you got are mounted much more forward than your stocks, so they somewhat blend into the A pillar. Hopefully you can get back to this project, and I've been buying stuff for mine and trying to get customer projects done so I have space to pull mine in for a heart transplant(a 400 sbc if the lb7 6.6 duramax won't fit) and redo the interior so I can drive it again. Keep up the good work.
6 month bump?
