Well that escalated quickly.
How did we get here? Follow along dear viewer, and let’s find out.
When I made this as a boxed section, I knew I was going to need extra material on the edges to tie back into the factory floor boards. I’m not as concerned with how the back is going to look once everything is welded in as it’ll be underneath the seat, but I wanted the front to tie in as smoothly as possible in case it’s visible through the carpet.
So when I bent the edges, I made the back 1 1/2”, and the front a full 3”. This’ll give me lots of material to play with. This is the side profile of the floor pan traced onto the front edge:
The two vertical lines represent my cut lines as in between the two is where the floor is mostly flat and I don’t have to do anything special there. After those cuts were made, I removed that middle section. It’ll weld flush to the floor as seen here:
Next is where things got a little tricky. I wanted a nice gentle radius from the bend down to the lower parts of the front floor, so after a little experimentation, I came up with a simple deep socket in the radius I wanted clamped in the vise:
I formed the first section around the socket with the body hammer as best I could, and ended up with this:
After flattening out the un-needed excess, I next transferred the factory dimpled depression onto the excess.
A little bead roller action will help with that authentic feeling, it’s always a good day when you get to play with the bead roller!
End result?
Not the best picture, here’s a little better view.
Next up was the section directly beside it. I repeated the forming around the socket process, just this time slightly lower to meet up with the different elevation.
The last section on the front was the most difficult as I had to bend the radius at an angle. I don’t have a good picture of it, but you can see a little bit of it in the middle/bottom right of this pic:
That about finishes up the fitting of the front to the floor, at least for now. I’m to the point where I need to start welding this in solid so that I can hammer and dolly the metal around in the more difficult transition areas.
On the backside of the boxed section, I just trimmed off the excess material from the areas that didn’t need it. The welding will be done in the angles where the two pieces meet up.
That just leaves this guy, the catalytic converter hump. It needs a haircut.
You can see the top of it needs to come down considerably:
So how do we do that? The same way that top chops are done. Hack the top off and drop it down. Except when you do this, the top is no longer big enough to fill the opening. So it has to be sectioned in half, and material added to the middle.
This is just done laterally in those pictures, the same will have to be done width-wise as well. So you basically end up with what looks like a cross in additional material that will need to be added to the middle.
But before I proceed any further on this area, I’m going to get the entire piece fully welded in first and tackle that at the end. Again, because I need some of the strength to be returned to the area so that things aren’t so floppy-flimsy and it won’t move around on me.
Probably going to take tomorrow night off, but Saturday the new piece will start to become one with the floor. 👍🏻
D.
