Whelp, the shop manual procedure write-up I had goes something like this:
1) remove skid plates
2) remove the inner cv joints and the front driveshaft from the diff
3) remove 4 differential mount bolts and pull it completely out
4) remove crossmember under the oil pan
5) remove starter
6) remove harness from front of oil pan
7) remove oil level sensor from side of pan
8) remove oil pan
And that's before actually replacing any bearings on the bottom end. If it was camshaft bearing material instead then there's a whole different set of tear down up top.
To be honest, the oil issue hasn't been traced down either. It's not in the tailpipe, but its not on the undercarriage. But it makes good oil pressure filled up hot and cold, throttle and idle.
So on my basic longterm todo list goes something like this: rear outer rockers, rear lower quarters, seat covers, a/c refrigerant leak, oil issue, bearing material issue, minor PS area weep, and a minor weep on the hydroboost unit.
It's a decent amount of work to put in that, $ for $, if I see another low mileage unit in the sub-$16k range I probably come out ahead selling this one off and buying another. Mainly it's the body/paint side of things that start to really add up. The rest is just time consuming while the garages are full with things I'd rather not have sit outside while this is torn apart an extended period of time.
It could be sorted out, and maybe will if it starts behaving itself.
Minus the cross member, that's how I did mine too. But since I had to dig that deep to do the cam, I just rolled new bearings in and that was the extent of the work I was committed to at the time. No bodywork for this guy, that stuff is spendy and tedious. Take a gander to the southwest for a rot free rig.
