Check oil level doesn't sound as bad as zero oil pressure. They can definitely drink oil, how many miles and how much oil was gone?
Whelp, the issue just happened/I learned of it right before the post I made. She parked it and I didn't bother checking the dipstick since it was hot. I'll find out when I drain it in the morning.
Miles are only 134k or so now. Oil change only had about 300 miles on it though, and everything was tight- plug, filter, etc. Thats as far as I looked with it hot and all..
Does it have an in-pan oil level sensor? Many engines of that time did, like my LT1. I wouldn't get to concerned if that's the case.
I believe so. I really wasn't in the mood to deal with it tonight so didn't double check that one. I know where the pressure one was, which, if the oil is really low perhaps the pressure sensor is also not reading right (as in how could it maintain a healthy pressure if the level was toast), but I didn't double check the level sensor location. It would be opposite side from where I went under the truck to double check the filter and plug and started to get mosquito bites so I gave up. (Garage was full and also too lazy to shuffle vehicles around to pull it in when I can just deal with it in the morning.)
What I'm not sure about is if/how the message center in these gmt800s might treat a double fault... as in, if the message generates for low level, would it also alert for low pressure and alternate? Or does just the first message display.
Had the wife told me AS it happened, I'd have told her pull over, shut it off, and I'd come dump some extra oil in just in case. Or let aaa tow it home. At least she only drove it across town about 10 minutes like that so it could be worse. Which is half the reason for draining the oil just to see exactly how much is there, if low did she do any damage if the pressure sensor was wrong or not showing correct... meh, who knows. Tomorrow will tell. Glitter in some very low oil would make me mad though.
Since we've owned it I've done 2 oil changes so far. It seems to use less than 1/2 qt every roughly 5k miles or so which is pretty good for these 496s.
