theoldsone daily build
Part # and part. The other stuff would be off the Monte SS frame. Like steering and front sway bar.
ENS-3-18110R
HYPERFLEX KIT CAR
UPI-3000-R
BUSHINGS
TMK-SET6
Wheel bearing inner
MOG-K5248
SWAY BAR BUSHING KIT
ENS-3-9102R
Bump stop
BEL-8006
NITRO DROP 2 SHOCK
OPG-ADDC292
REAR SWAY BAR
WST-11312
SPINDLE G BODY
SUM-BR-62013L
DRILLED AND SLOTTED ROTOR
BEL-5836
MUSCLE CAR SPRING KITS
Got my front suspension put together and oh man can't wait to thrash on it. General Lee jump and all. 18" wheels coming soon rears will be a healthy 9.5" width with the frame notch. Fronts a modest 8" width. Will look A1. Once the spring rolls in I will be hitting the body/floor repair... HARD! Frame notch area will be welded in with a 1/4 in plate, UMI rear shock brace will reinforce the rear much too.
Got the rear emergency brake hardware and shoes, bought both rear backing plates. Finding non rusted ones in the junk yard is hard and a pain to remove.
New axle seals put in.
Got frame notch is coming together pretty well. Probably the most labor Intensive thing to do on the frame the 1/4in steel is tough!
Got My rear disk brake system converted pretty well. Rotors look massive. I did keep the stock brake setup up front, just upgraded the front rotors and some EBC brake pads for the sake of keeping the cost down. IMO looks good and I'll bet it'll stop better too. Have to buy the calipers and lines next...
