I tested the one I thought was bad today as I used a heat gun to heat it up. It is good.did you test the switch before you ordered another one?
How will I do this?you should check the ground on the switch when the switch is installed in the intake with a mutimeter...
There's a thought- does the rear port have coolant? Can you move it to the front?Maybe the position I have it in the back of intake? I let it get up to over 230 and still did not come on. My temp gauge is in front of intake driver side. The switch rear passengers side.
