I have had a great time building this car, but I can now consider it almost "done". In the 4 years I've had it, it received all new engine, trans, rearend, driveshaft and paint. It runs 11.50's in the heat here in Las Vegas and if I go any faster I'll have to put a cage in it. Since I have a big block Vega as well, one car with a cage is enough. My thought was to drive the car more, but being a nice looking G-body I'm afraid to let it out of my sight. I'll take it to the track and occasionally to work, but that is it. Add to that the last 2 times I drove the car I got pulled over for stupid crap. That pretty much put me over the edge.
I'm thinking of getting something I could drive every day and not worry about leaving in a parking lot or outside my garage. Probably a 04-07 CTS-V. I was hoping the members of the forum could help me figure out what a decent 84 regal is worth - or change my mind about selling it. Any input always appreciated.
Here is the basic setup....
1984 Buick Regal
2 year old gunmetal gray paint (quality job), always garaged
Desert car with ZERO rust
Decent stock interior with reupholstered driver's seat
Engine:
383 sbc O-ringed block
Forged flat top pistons w/2 valve reliefs
Eagle rods
Engine Quest Heads. 200cc intake runners, 64 cc chambers
Solid copper head gaskets
Crower Solid Roller 00426S grind
ADV Duration 288/290 Lift .570 .584
Duration @ .050 250/252
Comp 1.5 Stainless Rockers
Crower springs
Victor JR intake
Holley 750 Double Pumper with Proform main body
Hooker headers, small primaries, 3" collectors
3" dual exhaust w/x-pipe, no cats, mandrel bent
MSD Pro-Billet HEI
Drivetrain:
700R4 Trans -built everything A+
Trans temp gauge
JW Custom 4000 Stall 10" w/full size lockup plate.
4.11 Gears
Mosier Axles
Grand National 8.5" 10 bolt posi
27x11.50x15 Hoosiers on Weld Pro Stars
Misc:
Car weighs 3390 lbs - A/C and heat removed
150 hp nitrous plate system
Dual nitrous bottles in aluminum bracket
Nitrous bottle heater with pressure switch
Accel Nitrous Mastermind (the new digital one)
Line lock
Large aluminum radiator with electric fans
Trans cooler with dedicated fan
Runs 11.50's here in the thin Vegas air. 10's are easily possible with a little more nitrous. Drives great and cruises around 2000 rpm on the freeway with the overdrive.
1984 Buick Regal
Engine:
Eagle rods
Crower springs
Victor JR intake
MSD Pro-Billet HEI
Drivetrain:
Trans temp gauge
4.11 Gears
Mosier Axles
Misc:
Line lock
