I did touch on it for a research paper for my business communications class actually, but not nearly as in-depth as what is truly needed. It was just something for an easy grade. What I did find is that in my area, 1999-2003 5.3 truck engines can be had for as little as $650 (car-part.com), but I don't know whether that includes all the accessories, computer, wiring, ignition coils, or even a throttle body. Still, working under the assumption that the engine does include everything (although I highly doubt it), by the time you add in the main aftermarket parts to make the engine "bolt in", you're well over two grand. This is looking specifically at G-body install parts, and includes an oil pan (ChevroletPerfomance seemed to be the best price), engine mount adaptors (Dirty Dingo), flywheel or a spacer ring to connect it to my 200-4R (Brian Tooley or Dirty Dingo), and some used F-body exhaust manifolds which some say will fit, which I priced at $75 each, used. I juggled around a few basic ideas to get the fuel system converted for fuel injection, from welding a sump to the stock tank and running an external pump, to the conversion kit from Gbodyparts.com, and basically you're spending $300-$400 for the most basic setup, but the sky is the limit on what you could spend. This still didn't get into bracketry to relocate the AC (which my car WILL have AC, and I WILL NOT cut the cross memeber), or the multitude of other things- Reflash the computer, making all the sensors work with my gages or buying aftermarket gages, cooling system upgrades/connections, and god knows what else.
The point of the research to begin with is a friend tried to convince me that I could get an LS in my Regal and driving for about a grand. But short of stealing all the parts, there's no way. My eventual goal is to buy a wrecked 6.0/M6 GTO and rob everything from it and sell off the carcass, but that's several years away. Hell, by the time I get around to it, the new LT1 might be a better choice to swap.
