The accelerator pump cam is right on the side of the throttle arm just below where your throttle cable hooks on. If it's still the stock pump cam it will be orange I believe, it is held in place with a small pan head screw. It has two holes in it, the #1 hole brings in the squirter shot a little quicker but the #2 hole will give it more volume, you can try that first. Or you could buy a pump cam kit and experiment with which works best. The cams go in order least - most by color: White, Blue, Red, Orange, Black, Green, Pink, Brown. Also possibly jumping up to a 31 squirter may help, but I would try working with the accelerator cam first. Start with making sure the slack is out of the pump arm, then work from that.
