Okay I am getting frustrated trying to tune my motor better. Okay it is pretty much a bone stock chevy 350. Standard bore and stroke, eagle rotating assembly with hyperutectic pistons. very mild flat tappet cam w/ stock 1.5 stamped steel rockers. high volume oil pump and street fire distributor. I have had timing @16 initial with 32 total. I have the idle in park around 850-900rpm. The idle just seems a little low and so does the timing. I am honestly afraid to bump timing up. My heads are also extremely stock 1.94 76cc and carb is 650cfm holley vac 2ndry. I am just looking for a little guidance.
