Has anyone ever measured the amount of crankshaft degrees that is acceptable for timing chain slop? If you put a socket on the crank nut you can turn the crank a little before you feel the chain tighten against the camshaft gear. I know when it is new there is no slop but even a week of running will stretch it a bit. So when does the slop become unacceptable? How many crankshaft degrees of turning back and forth constitute a bad chain? This on a Pontiac 400 but most standard V-8's use the same set up. I feel this chain is so bad it is retarding the cam timing. Without mounting a degree wheel I estimate this crank can turn about 45 degrees in either direction. Seems excessive.
