I have an aftermarket aluminium timing cover that wasn't cheap and looks to be a good quality part and it came with the seal installed. I went to change the front seal since the front had a minor oil leak and I hate oil leaks no matter how small. I tried a Napa seal and a Felpro seal and both fit snugly but were not an interference fit. I glued them in place but I'm thinking if this cover is not as good as it looks. I couldn't find any reason for the minor oil leak so I'm wondering if the opening for the seal is off center and allowing a little oil to seep by. I can't find any seal that is a few thou larger than an OEM seal so my thoughts are it could be the cover is junk. Anyone else have an aftermarket cover that takes a different seal?
