Tire rub help?
I have
P225/70r15
There's your problem.
Caster is good. so aligning the upper arm further forward to keep a large tire off the plastic can result in worse handling and wandering on the highway.
To run 16X8's with 255/50's (26.1" diameter) I had to take a sledge hammer/heat gun to the liners and they still just rub slightly when the tires are new.
pagrunt pointed it out in post #10, the uppers are on the wrong sides. The long side of the upper is supposed to be on the back side. The long side of the upper is on the front and you can see the spindle leaning back at the top because of the wrong upper. That is throwing the wheel back causing the rub....
img_1257-jpg.61764
img_1257-jpg.61764
The Upper control arm has a "gutter" on the back side. If they were reversed, the gutter would be on the front side.
I don't see a gutter in this picture. That looks like the front of the arm to me.
I agree with you but that looks like an aftermarket, maybe doorman, so I don't know if they are designed the same as OEM. It would be nice if the op can take a look to see if the offset is towards the front.
