Am I the only one who thinks his spindle is leaning in really far? Has it been aligned?
I think it looks like it's leaning back and the wheel is turned out a bit making the spindle lean in as you noticed. The upper and lower ball joint are supposed to be in the same axis.
Dorman's pictures on the web have the gutter in back:
I would think if the arms were swapped with 27.5" tires, it would be rubbing in a straight line.
My T-type has G-body parts arms and 26" tall tires on GTA's rubs pretty good on the plastic at large angles.
I have seen pictures of a doorman upper control are for an S10/G body didn't seem to have the gutter. I don't know if they were all made them same, different Chinese factories perhaps...![]()
Damn I just notice that thanksThere is an "R" stamped on the right side Arm above. It should be visible from the engine compartment with a flashlight, just outside of the inner fender.
