Tires rubbing the frame on my 86 regal
XCESSIV6
Apr 5, 2012
74
6
Cincinnati Ohio
a few pics
Regal86
9
the person who did the wheel tire combo on my car really didnt think too clearly haha, the front wheels were 15x8 with a 4 1/2 backspacing and the rim was grinding on the control arm. ended up swapping the 15x8 welds with a 4 1/2 backspacing from the front to the rear and had 255-60-15 tires put on them, they fit great. ended up putting 70s style 15x7 rallye wheels on the front. rides much better now!
1983regal
263
St. Louis MO.
XCESSIV6 said:
I RUN 18X10 WITH 4.75 BACKSPACE AND A 275/40/18
YOU CAN RUN UP TO A 305 WITH A 18X11 WITH 4.75 BACK SPACE AND NO FRAME MOD ON THE REAR
YOU CAN SEE MY CAR AT
MY CARDOMAIN SITE
http://www.cardomain.com/rides.2502956
I have 15x7's with a four inch backspace and am against the frame on my regal, how the heck are you running that big of a rim and backspace and not having issues?
9,640
12,774
The problem is an 18" tire combo fits completely different from how a 15" fits, on an 18" you have a short tire on a large rim with a small section width by comparison. On an 18 x 10 with a 275/40 you are only at about 27" tall or less and your section width is somewhere around 11" on a 10" rim.
My 15 x 8.5 rims with a 28" tall 295/55 has a section width of just under 12" and if I put my tires on a 10" rim the section width would increase to around 12.5" and the section width is where you end up having frame rubbing issues.
V6UnderPressure
202
New Lenox, IL
MY CARDOMAIN SITE
What year regal? My Grand National has 17x9 with 4.5" BS with no rubbing issues whatsoever. :?:
LS1GN
600
Central Florida
exactly - my 17 x 8s are so big they clear all my front steering/suspension components, but the tires are small so there is a little rubbing, but not much.
mebe007
1,808
4
36
newport news, viginia
MY CARDOMAIN SITE
I have 15x7's with a four inch backspace and am against the frame on my regal, how the heck are you running that big of a rim and backspace and not having issues?[/quote
I had the same issue with my 15x7 wheels with 4" backspace, switched to a 15x8 rally with 4" backspace and the issue went away. weird huh
9,640
12,774
MY CARDOMAIN SITE
If you had the same tire and put it on a wider rim with the same BS it brings the tire out towards the outside of the car and pulls the section width a little further that way also, which is why that could solve a mild rubbing issue.
Regal86
9
Ok so im finally going to buy matching welds for the front. Should i do 15x6 or 15x7 and what backspace should it be?
