Torsen 28 spline posi upgrade
About 85K. I already have 3.73s in another axle, and it would be good to have the higher ratio for cruising. I'll get the cover off on Friday and get some photos.
Are they gm parts or after market? I just got my set up today. I'll post pics in a little.
It's a stock GM axle from a 2000 Camaro. Picked it up for the disc brakes. I didn't realize it was a Torsen until I got the cover off. There;s a little dink in the tone ring (part of the differential) when the yard drained the oil, but the ring gear was not harmed.
Here it is. Let me know what you guys think. I think every thing is here. There's a chip or 2 on the pinion head.
I saw one chip in the picture, at the root of the pinion gear tooth, where is does not look like it impacts the interaction with the ring gear. You said there was another chip. Where is that one located.
To be clear, I am just looking to swap the ring and pinions.
Yeah I'm pretty sure there was a second one I'll have to look at it again when I'm home. I'll take a picture and Post. Yeah I understand just the ring and pinion possibly
I must have just seen the same chip twice because I'm not seeing another one. Just the 1
