My old TPI setup did the same thing with the cone filter just mounted on the front. When I redid it to the twin CAI it made a huge difference!I just revisited this and thought I’d post a couple pics of the CAI that I built to make the cowl hood functional . Since I just had a filter on the throttle body, as soon as the fans fired up the performance would drop.
Is that a TPI or a Ram Jet? Hard to tell next to old-school valve covers.
Whose? Mine or Xitabl's?Is that a TPI or a Ram Jet? Hard to tell next to old-school valve covers.
Yours, although Turna may have called it. I thought LT4s used centerbolt heads...unless you have adapter s under there to enable the talk valve covers.Whose? Mine or Xitabl's?
Actually, my old setup is a Holley Stealthram EFI intake which is based off the speed density TPI intake prior to the LT4. It uses TPI style Bosch injectors, throttle cable, has a 1000cfm BBK throttle body and kicked tail. The intake is for the old school sbc design, and is currently residing in my basement waiting for someone to buy it.Yours, although Turna may have called it. I thought LT4s used centerbolt heads...unless you have adapter s under there to enable the talk valve covers.
