TPI in a Monte Carlo SS
Thanx 86. Who is a reputable & inexpensive company for programming? Will places like CompCams do a program for my computer if I buy a cam from one of them with my engine specs?
Nice site. Plenty of info and sounds reasonable. Thanx Malibu.
I used PCMforless.com for this last chip. I haven't got my engine in yet and it's a new rebuilt 383 so I wanted a safe start-up chip. I'm running a 230/236 113* LSA hyd roller, SuperRam intake, 30# injectors, AFR 190 heads, etc on my 383/T56 combo so a stock chip wasn't an option.
If you can learn chip tuning, you can buy everything you need to burn your own chips from moates.net. Look for an AutoProm.
Hopefully I get mine in and running before winter sets in ... :roll:
As their anyone near Atlanta that has done a TPI swap? I am swapping a 1986 350 TPI into a 79 regal and am having some technical difficulties with the wiring. I have reached the limit on my budget so Howell or Painless wires are out of the question. Or is their anyone that will rework my factory harness?
Thx in advance
Thx in advance
I'm in Acworth, 30 miles north of Atlanta, and do injected swaps pretty often. I mostly do LSx swaps now, but I could probably help you. As a matter of fact, I pulled a TPI 305 from a customer's '83 Malibu wagon recently, and still have the wiring harness, computer, and in fact the entire TPI system...polished runners and plenum...and I'd consider seperating the harness and computer from the polished pieces if you want them. Yours should be a MAF system, but the one I have is a speed density system with a 730 style ECM.
How does the tpi compare with lsx motors based on Power and ease of installation?
I have had both done so far my 1980 lemans came with a 3.8 v6 and that was retrofitted with a 408 tpi sbc, and a vortec 4.8 gen3 in my monte carlo. the major thing was the wire harness for the two. thats what really amke or break your swap.it can be high on price.but they also make a lot of different dyi harness now these days since efi is becoming very popular over carb.the motor mount is another thing to worry for the lsx swap or a vehicle that originaly had a v6 in it place.
as far as power my 408 sbc is a brute animal it get decent fuel mileage only because i have a overdrive trany and kept the stock 2.56 rear end gears.4.8 in monte carlo is a screamer and get damn good gas mileage.its fast also the motor still has a lot more to offer.
so to answer your question the in the two engines were worth it.but it is matters to have a good mechanic that you can trust to do the swap.thats what what makes the difference also.
