I just joined a few weeks ago. Thought I'd introduce myself and my "TPI" swap.
Started out with an 84 Cutlass that had a 3.8 in it. Swapped in a 350 Chevy carbed. Had a flat tappet cam go flat and scored the crank. Instead of feeling a set-back, I decided since I was going to have to find a differant crank, it was time to build a 383.
Built a 383 with a cast steel (no-name brand from machine shop) crank and KB hyper flat-top pistons. Had a 218*/224* .495"/.502" 112* Comp retro roller cam with Summit roller rockers. AFR 190 (pre Eliminator) heads with TPIS Big Mouth base and SLP runners. 24# Accel injectors and adj pressure regulator. I also ran a Monte tank with a Cutlass filler neck soldered in. A Howell harness was used with a Granitelli 255 lph in tank pump. Hedman shorties dumped into dual cats. A TPIS level V chip was controling the 87 MAF system.
A World Class T5 was run behind it with a Centerforce 10.5" clutch and pressure plate in an 88 Camaro bellhousing. Actuated by using mid 80's Camaro pedals and the stock type hydraulic setup.
I wasn't real happy with the hyd clutch setup and had since bought a used SuperRam setup and new Aftermarket Tremec T56 trans. I removed the TPI setup and added 30# Ford SVO injectors and installed the SuperRam and then had Ed Wright of FastChips burn me a new chip for my computer. I had them burn the chip for an 89 Camaro to delete the 9th injector. I then pulled the old T5 and stabbed in the T56 along with a Lakewood bellhousing for an 83 Camaro which used the mechanical linkage instead of the hyd setup. SpeedDirect linkage replaced the stock worn-out linkage rods. A Spec Stage 3 clutch replaced the Centerforce clutch pressure plate assembly. After having the driveshaft shortened for the new T56, I had a set of 3.42 gears put in the 7.5" rearend.
This setup ran hard until a broken piston derailed added progress.
Seemed like I was making 1 step forward and 2 steps back. Engine needed rebuilt yet again, the AFR heads had some pitting from the broken piston so I had them fixed which also made the combustion chamber slightly smaller. The body had more rust than I had time or money to fix... on & on.
I located an 86 Cutlass Supreme body with a 307 Olds engine that ran like *%@* but the body was straight and fairly rust-free for an Illinois car. Stripped the 84 of all good parts and I'm now in the process of putting my Claret bucket seat Salon interior in the 86 after pulling the blue bench interior out of the 86.
The 383 will get an additional .010 cleanup making it a 385 now. A Scat crank and stroker rods will replace all questionable parts along with some new pistons with a 12cc dish to keep compression around 10.1 with the added bore and now smaller 66cc heads. I am stepping up to a 230*/236* 113* Comp XFI 280 roller cam. Comp beehive springs and an AFR rev kit will now control the valves.
I am also moving up to an 11" Centerforce clutch and pressure plate. The old flywheel was a 2 piece rms 305 flywheel which needed a balance plate between the crank and flywheel to account for the external balance. My new flywheel is the correct style 400 balance and I can now run a bigger clutch.
I hope to have it mobile under it's own power again by mid - late summer. Key word... "HOPE"!!!
Sorry it was so long but I've been a long way with my beloved G-body and the ride continues as time and money permit. Once it's done I bet it'll become my daily driver. It'll probably be too da!! fun not to drive!!!
Thanks for listening and reading this far if you did.
Doug Gulley
tpiolds@yahoo.com
86Cutlass383SR
