My ecm is putting out a code 21. Im getting around 5 volts out of both of my positive tps connector wires when the pigtail is unplugged, does my ecm need to be replaced? the shop manual says one of the wires is supposed to be WELL under 2.5 volts... Its a ccc em4e quadrajet, 1986 Monte Carlo base 305 vin H
Coming from the ecm you have a three prong connector. you have the ground wire, the 5 volt wire and the other wire thats supposed to be low voltage. mine "low voltage" wire says 4.777 when the plug isnt plugged into the carb. The manual says its supposed to be below 2.5 volts when unplugged.. How can i check this circuit, or the ecm? i tested for continuity across the tps plug, There were no wires shorted to each other. Should i get a new ECM? How do i make sure the new one doesn't fail?? Help!
