dang,i had no idea it was that small.did you just pull it out of the pool or something??
good info.
good info.
yes
good info.
good info.
I thought I read that stacked plate is better than tube and fin.... Or, is it th he other way around?
Yes and much more durable as well.Stacked plate is better than a tube and fin. Junior's Cutty runs a 11x11 Hayden mounted in between the intercooler and radiator and works well. I'm going to run the same out in the open with a 10" fan. The Cutty never hits 150 degrees on the trans temp.
I don't see how that dinky in-rad trans cooler could possibly do much for heating or cooling purposes. Ever seen one? Here:
I put the biggest Derale I could find in.
Sorry, boss, but I ain't buying that a single pass for 7" through the liquid is that effective.It goes back to basic science. Heat transfers by either conduction, convection, or radiation. Conduction is the quickest while radiation is the slowest. Its why you feel colder in water than in air at the same temp. Water (liquid) conducts heat out of your body faster than air (gas). A liquid to liquid heat exchanger does not need to be as large as a liquid to gas heat exchanger because conduction is 32 times faster than radiation.
If you can swing it Motion Raceworks has a nice kit for $289 with Fragola brand lines and fittings, that is what i just got in last week. Its a solid piece for the money!i'm in the process of ordering a tran cooler for a olds 455 with a 350 transmission . looking to buy the hayden 678 or 698, would like to know if there is a big difference, and maybe some advice on the best one to choose . i'm planning on bypassing the radiator and just run the lines to the trans cooler. i saw a post where someone used what seem like a inline filter is that something to also consider doing . will appreciate any advice or opinion.
