newbie here have a 84 elky with a 700r4 trans that will not shift into od or 4th any suggestions on how to daig the problem how the shift daigrhams or ?? thanks in advance
I can only offer very basic info: I did a 700r4 swap and controlled clutch lock up with a switch. Also important that the carb to trans cable be adjusted correctly.( It's been 20 years, I forgot all the good stuff)newbie here have a 84 elky with a 700r4 trans that will not shift into od or 4th any suggestions on how to daig the problem how the shift daigrhams or ?? thanks in advance
nothing been done under hood lately still has ecm although some items are missing also looking into aftermarket controller any suggestionsI can only offer very basic info: I did a 700r4 swap and controlled clutch lock up with a switch. Also important that the carb to trans cable be adjusted correctly.( It's been 20 years, I forgot all the good stuff)
thanks for the input guys, would like to know how to diag the problem . such as what makes the trans shift what controls the shift , how it works
It's a simple trans...no computer connections. The TV cable adjustment controls shifts and an electrical connector on the trans controls the clutch lockup.
