trans problem 700r4
That's for the TCC lockup IIRC
ok now I now where I should be looking what tells the converter to lock up and when, is it rpm road speed eng vaccum ? and how do we diag this problem
shifts great into all gears just no 4th or od or converter not locking up trans works ok to that point then acts just like a 3spd trans, which is leading me as to what makes it go into overdrive
4th is overdrive, the last "shift" you usually feel is the torque conv locking in...
Reactions: Texas82GP
If it shifts into 1st, 2nd, and 3rd and you don't feel ANYTHING after that, it's not going into overdrive which means the torque converter isnt locking up with the engine. Needs to shift Three times essentially. 1-2, 2-3, and 3-4(OD).
