Transmission change
olds4ever
35
8,832
7,793
A turbo 350 is a bolt in, you can even get a lock up version. Just the cross member needs moved forward. I personally am not a huge fan of the TH350. If you insist on the TH400, get the BOP short tail and a 32 spline output yoke, it should be close on length and cross member stays where it is. You will probably find you want a rear gear change after a few long highway trips.
