Transmission Dilemma
Stock looking kit. Other than changing some areas where there are thrust washer to Torrington bearings, (not cheap), this kit should do you fine. The master kit that was previously posted looks like a stock kit, with decent parts. ALL kit suppliers buy their parts from the same sources. There are only about 3 gasket/seal kit packagers and only 3 maybe 4 friction plate manufacteurers so don't get too caught up in brand names on master kits. The boxes may have different names on them, but the parts inside are as I mentioned previously. So long as the friction plates are from Borg Warner, Raybestos or Alto, you're good to go there. Steel plates if new and not tumbled old ones only come from I believe two sources.
