Nope. If your needle is jumpy, you'll need to lube your speedo cable. You'll have to remove the cable from the casing at the upper end to accomplish that.
Bill
Bill
very true, before i purchased my monte it sat for over a year...i will have to get my hands dirty and actually get under there and check it out01cherryreds10 said:I would try getting a filter kit from your local parts store. It should come with a new gasket filter, and the little paper gasket for your filter. I bought a Purolater one for 10 bucks. My trans was leaking when I wouldn't drive the car, and it was a very slow leak. So I just took a swing in the dark and replaced the filter and pan gasket and it definately doesn't leak like it used to (crosses fingers). I don't know if it's a proven fact but I think that the cork gaskets like to swell up when the car is rarely driven. At the dealership a customer comes in with a mint condition 84' Camaro with 20k on the odometer and has had at least 3 oil pan gaskets replaced because the owner just doesn't drive it.
