hello Gbody lovers!
ran into a little problem today. had a transmission fluid leak(th350) from a cooler line so i replaced the steel lines with braided lines because why not right . After changing the lines and putting fittings on i experienced a worse leak than i started with. i have pictures of where the leak is coming from but not exactly sure what i need to replace it. i believe we this is the base of the dipstick but not completely sure. if i could pick some brains and get some insight that would be greatly appreciated. (pics attached)(located just below trans cooler lines on th350)
