Transmission to speedometer cable question....
WV CHEVY MANN
248
285
West Virginia
Good afternoon forum...I am going to order a speedometer cable for my 1980 Malibu. I have a 700R4 transmission in the car at present. If I order a speedo cable for that transmission would it hook up to my stock speedometer? Just checking before I order. You guys know your stuff here 4 sure. Thanks in advance for any help here....
ssn696
Living in the Past
5,551
6,692
Permanent Temporary
When I replaced a TH350 with a 700-R4 and later a 200-4r, the stock cable plugged in both cases. Not sure if the speedo gears are the same so you can transfer the set to your 700-R4 so the speedo remains correct for the rear end ratio.
WV CHEVY MANN
248
285
West Virginia
Hello and thanks for the info .. Sounds like I would be ok to order the cable then.. I appreciate the response my friend ....
