Trim nipple removal?
I'll give it a shot if it gets messy out comes the dremel.
I would say whatever keep heat down the most. Maybe cut them close, then gently grind them smooth. I'm fortunate my Cutlass doesn't have the wide trim...less rust issues and less work to smooth it all out.
I agree. Cut as much off as possible and then grind the rest keeping as much heat as possible out of your body panel to prevent warping.
Cut off one bottom nipple got nervous so I stopped,,, see what the response is
Hay T my guy finally called me back unfortunately I was on the belt parkway at the time and not taking calls but I will get back to him for you
Great thanks!!
How does that nipple look?
