You don't regap rapidfire plugs they are pre gapped at 45 because of the design of the electrode.v2vera said:pontiac gp said:unless you know who your talking to at a parts store DO NOT listen to them but if you do double check before using their suggestions
ok WILL DO 🙂 now I'm doubting the plugs they gave me lol They gave me AC Delco Rapid Fire spark plugs. Will this work fine? What do you suggest?
They should be # 2 Rapid fire plugs And you don't use dielectric grease under the coil it is for the the ends of the plug wires only. Your plug wires should be fine. just gap the plugs at 45 and replace the cap and rotor,(don't forget the ground strap for the coil)
