Turn Signals Not Blinking
85Regal801
46
31
Hello all,
So I recently upgraded to LED bulbs in my Buick front and rear and figured I’d have to up the flasher too. I installed everything and the hazards work when the lights are off but not when they’re on. Also blinkers don’t work at all. Checked the fuse box and I only have connections to the hazard flasher but not the turn signal location? (With halogen bulbs turn signals worked fine) so I’m a little confused as to WTH is going on lol any input is appreciated
pagrunt
9,168
15,350
Elderton, Pa
The LED doesn't put the electrical load on the curcuit like standard bulbs. With this the stock flasher fuses will either hyper flash or not flash at all. Two of these whould get things working again.
85Regal801
46
31
Oh ok yeah I have the led flasher but like I stated above on my fuse box I don’t have any connectors on the turn signal flasher spot, what’s weird is that before I did anything with the bulbs or flasher they worked fine
pagrunt
9,168
15,350
Elderton, Pa
Don't know why they did it but GM didn't always put both fuses in their spot in the fuse box. The "missing" fuse should be in a PIA spot behind the dash then. It could be in a metal clamp bolted to the dash itself or part of the harness that houses the key & seat belt buzzers & horn relay. That should be bolted to dash near the parking brake release.
85Regal801
46
31
Just my luck lol do you have a picture or something I can ref? It’s a damn rats nest down there lol
