Hello,
I'm working on a non-standard build, I am using a 5th gen G-body frame under a 1941 Chevy Coupe. The frame fits nicely under the car as the wheel base is with in a inch of the original length (excluding the frame rail ends, which get chopped off). Currently, I have the ride height set at where I would like it to be, which is low. I want to going to go with coil-over's instead of airbags. Once I set the ride height, I'm not interested in really changing it. I do plan going with a tubular UCA & LCA, but I have to figure out how to correct my positive camber issue, and looking for a shorter UCA.
I have read a lot of forums about swapping suspension parts between A, B, and maybe F Body cars. My primary question, is there any source that compares the differences between the LCA & UCA's from the A, B, G, F body makes? Mainly lengths (as it sounds like the mounting points are the same)? And which spindles are the shortest?
Thanks for any input.
