85 Cutlass Brougham said:He is NOT starting with a turbo 6 powered car to begin with! As a swap, it would be quite expensive to get all those used, 24 year old electronics parts (and wiring harnesses) to work well together in a swap application. As far as using a newer technology engine is concerned, I would put an LSX/6 speed swap in a G body before I would do a turbo 6 swap. I do not doubt the potential of the turbo 6, but I do not think it is a cost-effective swap into a more mundane car. I looked into it in 1996 when I did my car's swap, and decided the SBC was the best option. Also, a poorly maintained turbo 6 would likely need internal work at the kind of mileage a car of this age would normally have. The Buick 6's poor oil pump design is a well known issue, and back when these engines were common in the 90's, it was quite common for them to spin bearings due to lack of oil pressure caused by excessive timing cover wear. It may not have been as common in the turbo community due to the greater care most of these cars likely saw, but it is a common Buick V6 issue.
Also, turbo cars are quite pricey to buy. A serviceable example is usually around $10k, while a basic 2 door Regal is usually anywhere from free to $3500. A Chevy swap is VERY cheap too, and can be had for under $2,000 if you are lucky, know what you are doing and use used parts. Building an 11 second SBC G body is MUCH cheaper than building an 11 second Grand National when you factor in the purchase price of the car and all attending mods.
As for me, I am NOT a car snob. I really don't give a sh*t about heritage or correctness as long as something works from a technical standpoint. The purists can have their correctness, old technology and such. I prefer to combine whatever technologies I see fit to achieve the functionality I have planned.
You might not be a car snob but you dont know what you are talking about.....
THREAD POSTERS:IF YOU ARE NOT A COMPLETE DUMBASS,READ THE ARTICLES BEFORE YOU REPLY SO YOU WILL NOT HAVE TO BE CORRECTED
