UMI Performance New Product- Pro Style Rear Sway Bar
UMI Performance
GBodyForum Sponsor
Jul 9, 2011
352
42
Philipsburg, Pa
www.umiperformance.com
Adjustable Pro Tour Style Rear Sway Bar for the 1978-1988 GM G-Body
P/N: #3044
Price: $399.99
UMI Performance, Inc. is pleased to announce the availability of our newly designed Pro Tour style rear sway bar for 1978-1988 GM G-body applications. This 1” dia hollow sway bar is axle tube mounted using our tried and true 2245 serrated tooth mounting clamps, poly bushings and heavy duty u-bolts. Three position adjustability delivers street, road race/auto-x and light drag race performance all from the same bar. Adjustable length race style rod ends allow a perfect fit as well as preload capability for drag racing use. The P/N 3044 sway bar has been designed to accommodate the factory rear housing, GN 8.5, 12-bolt, Ford 9” and Moser M9 while still offering great ground clearance and a clean look. These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA – USA.
Website Link: http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=8_66&products_id=722
hey how is it going i have a 1980 monte street strip 4 speed with a 9 in and healthy sbc . do you think it will handle the hard launches of a stick shift car
Hey, good morning.
Our 1" tubular will handle that power and will function as a drag anti-roll bar when used on the shortest hole. The middle hole and longest hole allow you to soften the bar for street use.
In a few weeks we'll be debuting it's cousin, a full-on drag anti-roll bar with more rate and capable of flattening however much horsepower you can put in the car. It will make the car pretty loose on the street though...
Sign up for our newsletter or check here on gbodyforum for details.
http://www.umiperformance.com/catalog/i ... =subscribe
thanks!
ramey
