Umi sway bar setup question
bertscova
bertscova
101
It sayes in the instructions to sit in the car and measure from the ground to the bottom of the door jam and to raise the passenger side 1/16 of an inch higher and set preload. But how do I set the initial preload. Is the sway bar supposed to be straight, angled up a bit or angled down a bit. The sway bar I have has brackets that bolt to the chassis not the control arm
383_GrandPrix
383_GrandPrix
540
Quebec, Canada
You're best to message the guys at UMI directly, they're a supporting vendor on the forum and have an account. UMI Performance
Reactions: fleming442
melloelky
melloelky
2,069
mass
depends on what you're setting it up to do,i set up my pro tour bar as "neutral" Neutral means with the car sitting on all four tires, driver in seat, the end link (doesn't matter which side) slides in and out of the corresponding bracket off the frame easily. bar straight across,No torsion jacked into the bar.
Thread starter Similar threads Forum Replies Date
G T type 8.5 with 3.73s and sway bar, full set of brand new umi control arms G-Body Parts For Sale / Trade 9
AlexT MALIBU Coil over suspension....Detroit, UMI, or Ridetech? Frame / Chassis / Suspension / Steering 8
melloelky boston CL ad,not mine.good deal on rear umi control arms.upper and lower General Discussion 0
T FOR SALE UMI Performance Control Arm Reinforcement Brace Kit 3028-B G-Body Parts For Sale / Trade 5
UMI Sales UMI Christmas and New Years Savings! UMI Performance 0
UMI Sales UMI Black Friday sale starts early! UMI Performance 0
UMI Sales UMI Labor Day Sale - 10% off and free shipping - UMI Viking Koni UMI Performance 0
UMI Sales UMI - Free shipping in August! UMI Performance 3
C CUTLASS I’m thinking Umi 2” lowering springs? Any thoughts guys Frame / Chassis / Suspension / Steering 53
scotty49 12 bolt swap with UMI kit QUESTION! help! Transmission / Rear End / Driveline 10
39F ARB kit vs blazer sway bar swap Frame / Chassis / Suspension / Steering 2
pagrunt My home made rear sway bar/control arm inserts Frame / Chassis / Suspension / Steering 0
P Sway Bars - Front 34mm hollow (f-body) G-Body Parts For Sale / Trade 8
Mikko F-Body Hollow front sway bar install help Frame / Chassis / Suspension / Steering 7
39F Rear sway bar ONLY Frame / Chassis / Suspension / Steering 7
D Front sway bar problem Frame / Chassis / Suspension / Steering 8
8 Blazer Rear Sway Bar Frame / Chassis / Suspension / Steering 57
H CUTLASS Front sway bar bushing bolt mount stripped Frame / Chassis / Suspension / Steering 34
dickeymoore Sway bar removal or not ????'s Transmission / Rear End / Driveline 7
corkatoa Sway bar question Frame / Chassis / Suspension / Steering 6
565bbchevy Sweet roll bar General Discussion 9
80elky911 El camino roll bar rear bars inside car Frame / Chassis / Suspension / Steering 13
Michael Bennett Rear Anti Roll Bar for Drag Strip Traction Frame / Chassis / Suspension / Steering 11
CopperNick Project Regress--The "Z"-Bar gets raised, Again!! Chevrolet Monte Carlo / SS / Malibu 1
xylorex BMR Xtreme Anti-roll Bar Kit Frame / Chassis / Suspension / Steering 3
8 Grand Prix Bar Hardware Frame / Chassis / Suspension / Steering 8
